Ir para o conteúdo principal
Raleigh M20 Handlebars Replacement
O que você precisa
  1. Raleigh M20 Handlebars Replacement, Handlebars: passo 1, imagem 1 %32 Raleigh M20 Handlebars Replacement, Handlebars: passo 1, imagem 2 %32
    • Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...)
    • Using a 3/8" Allen wrench, loosen the nuts that hold the brake controls and gear shifters.
  2. Raleigh M20 Handlebars Replacement: passo 2, imagem 1 %32 Raleigh M20 Handlebars Replacement: passo 2, imagem 2 %32 Raleigh M20 Handlebars Replacement: passo 2, imagem 3 %32
    • Place an Allen wrench (size doesn't matter) under the bike grip.
    • Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
  3. Raleigh M20 Handlebars Replacement: passo 3, imagem 1 %32 Raleigh M20 Handlebars Replacement: passo 3, imagem 2 %32
    • Slide off the gear shifters.
    • Slide off the brake controls.
  4. Raleigh M20 Handlebars Replacement: passo 4, imagem 1 %32 Raleigh M20 Handlebars Replacement: passo 4, imagem 2 %32 Raleigh M20 Handlebars Replacement: passo 4, imagem 3 %32
    • Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
    • Lift the handlebars from the bike frame.
    • Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
    • Sit on the bike and make final adjustments to the positioning of the brakes and gears.
Conclusão
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
Jon Ribera
Membro desde: 09/26/12
72 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 7-49, Forte Fall 2012 Membro de Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 25
Ao todo: 2,381
