Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use an 8" adjustable crescent wrench to fit it into the base of the pedal.
Twist the the wrench in a counter -clockwise direction to unscrew the right-side pedal (The chain side).
Repeat the process on the other side with a clockwise direction.
Turn the wrench continuously until the pedal detaches from the crank arm.
Use a flathead screwdriver to remove the dust cap of the crank arm.
Repeat the process on other side.
Next, use a socket wrench to unscrew the crank arm.
Turn the socket wrench clockwise to remove the bolt.
Insert the crank arm puller into the screw hole.
Now use a crescent wrench to tighten the crank arm puller. Twist it in a clockwise direction until the puller is fully tightened.
Turn the crank arm puller in a clockwise direction to remove it.
Repeat step 2 to 4 on the other side.
Flip the crank arm over with the chainring on it.
Locate the four screws on the back of the chainring.
Use a Phillips #2 screwdriver to remove the four screws on the back of the chainring.
Hold on to the crank arm and pull out the chain guard gently.
Uma outra pessoa concluiu este guia.
