Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Make sure that the bike is upright and stable.
Make sure that the rear rack is fitted on the bike.
Place a screw to attach the rear rack to the frame of the tire.
Tighten the screw with a philips screwdriver by turning it in a clockwise direction.
Repeat the steps above on the other side of the bike.
Place the metal holder to be even with the bar sticking out of the rear rack.
Line up the holes. Place a bolt to attach them together.
Use a philips screwdriver to tighten the bolts.
Do this for both sides.
Make sure that the rear rack is even. If it is not, redo the previous step.
Locate the screws on top of the rear rack. Tighten the screws using a philips screwdriver.
Once the screws are tightened, you are done.
Uma outra pessoa concluiu este guia.
