Ir para o conteúdo principal
Rain-X Chipped Windshield Repair
O que você precisa
  1. Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: passo 1, imagem 1 %32 Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: passo 1, imagem 2 %32 Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: passo 1, imagem 3 %32
    • To remove excess glass, scrape over the surface of the chip with the included razor blade.
  2. Rain-X Chipped Windshield Repair: passo 2, imagem 1 %32 Rain-X Chipped Windshield Repair: passo 2, imagem 2 %32
    • Attach the Rain-X applicator base to the windshield, with the center of the base directly above the chip.
  3. Rain-X Chipped Windshield Repair: passo 3, imagem 1 %32 Rain-X Chipped Windshield Repair: passo 3, imagem 2 %32
    • Cut the tip of the repair resin bottle using the razor blade.
  4. Rain-X Chipped Windshield Repair: passo 4, imagem 1 %32 Rain-X Chipped Windshield Repair: passo 4, imagem 2 %32 Rain-X Chipped Windshield Repair: passo 4, imagem 3 %32
    • To attach resin chamber, screw the chamber into the center ring of the applicator base.
  5. Rain-X Chipped Windshield Repair: passo 5, imagem 1 %32
    • Screw the resin chamber clockwise until it is in contact with the windshield.
  6. Rain-X Chipped Windshield Repair: passo 6, imagem 1 %32 Rain-X Chipped Windshield Repair: passo 6, imagem 2 %32 Rain-X Chipped Windshield Repair: passo 6, imagem 3 %32
    • Apply 3-6 drops of resin from the resin repair bottle into the resin chamber.
  7. Rain-X Chipped Windshield Repair: passo 7, imagem 1 %32 Rain-X Chipped Windshield Repair: passo 7, imagem 2 %32 Rain-X Chipped Windshield Repair: passo 7, imagem 3 %32
    • To add the pressure driver, screw the driver clockwise into the resin chamber.
    • Make sure to tighten almost all the way.
    • Make sure the pressure driver is in contact with the windshield.
  8. Rain-X Chipped Windshield Repair: passo 8, imagem 1 %32
    • Set timer for 4-6 minutes - Let the adhesive absorb into the chip for 4-6 minutes.
    • To determine if the repair resin has absorbed properly, look at the glass from a 45 degree angle.
    • After the 4-6 minutes end, unscrew the pressure driver, turning it counter clockwise. Remove it to release any trapped air.
  9. Rain-X Chipped Windshield Repair: passo 9, imagem 1 %32 Rain-X Chipped Windshield Repair: passo 9, imagem 2 %32
    • Reinsert pressure driver by twisting clockwise.
    • This will discard any air remaining in the chip.
  10. Rain-X Chipped Windshield Repair: passo 10, imagem 1 %32
    • To check for remaining damage, look for a dark color to appear.
  11. Rain-X Chipped Windshield Repair: passo 11, imagem 1 %32
    • Leave to cure for 5-10 minutes.
  12. Rain-X Chipped Windshield Repair: passo 12, imagem 1 %32 Rain-X Chipped Windshield Repair: passo 12, imagem 2 %32
    • Once finished curing, remove the resin chamber and the pressure driver by screwing counter clockwise.
  13. Rain-X Chipped Windshield Repair: passo 13, imagem 1 %32 Rain-X Chipped Windshield Repair: passo 13, imagem 2 %32
    • Remove the applicator by using the tabs on the suction cups.
  14. Rain-X Chipped Windshield Repair: passo 14, imagem 1 %32 Rain-X Chipped Windshield Repair: passo 14, imagem 2 %32
    • Clean off any excess adhesive from the windshield.
  15. Rain-X Chipped Windshield Repair: passo 15, imagem 1 %32 Rain-X Chipped Windshield Repair: passo 15, imagem 2 %32
    • Cover the chip gently with a curing strip.
  16. Rain-X Chipped Windshield Repair: passo 16, imagem 1 %32
    • Move the car into direct sunlight and leave for 4-6 hours.
    • Remove the curing strip and enjoy.
Conclusão
Jeffrey Ritchie
Membro desde: 10/26/18
286 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S1-G8, Bender Fall 2018 Membro de UC Davis, Team S1-G8, Bender Fall 2018
UCD-BENDER-F18S1G8
Membros da 3
1 Guia de autoria
Um comentário
If you do not have a sunny day, what is the best UV wavelength in nm, watts, and length of time to fully cure the resin.
Thanks much!
AZRic - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 77
Duração total: 4,581
