Ir para o conteúdo principal
Raidmax Alpha Case Graphics Card Replacement
O que você precisa
  1. Raidmax Alpha Case Graphics Card Replacement, Graphics Card: passo 1, imagem 1 %32 Raidmax Alpha Case Graphics Card Replacement, Graphics Card: passo 1, imagem 2 %32 Raidmax Alpha Case Graphics Card Replacement, Graphics Card: passo 1, imagem 3 %32
    • Turn off the computer and the power supply to the computer.
    Pergunte ao FixBot
    Comentar
  2. Raidmax Alpha Case Graphics Card Replacement: passo 2, imagem 1 %32 Raidmax Alpha Case Graphics Card Replacement: passo 2, imagem 2 %32
    • Recycle the power in the computer by pressing the power button on and off again. This removes any remaining current to the computer.
    Pergunte ao FixBot
    Comentar
  3. Raidmax Alpha Case Graphics Card Replacement: passo 3, imagem 1 %32 Raidmax Alpha Case Graphics Card Replacement: passo 3, imagem 2 %32 Raidmax Alpha Case Graphics Card Replacement: passo 3, imagem 3 %32
    • Access the glass side panel by turning the back of the case to the left when looking at it from the front.
    Pergunte ao FixBot
    Comentar
  4. Raidmax Alpha Case Graphics Card Replacement: passo 4, imagem 1 %32 Raidmax Alpha Case Graphics Card Replacement: passo 4, imagem 2 %32 Raidmax Alpha Case Graphics Card Replacement: passo 4, imagem 3 %32
    • Remove the two screws on the glass side panel. These are thumb screws so they can simply be removed by twisting them to the left.
    Pergunte ao FixBot
    Comentar
  5. Raidmax Alpha Case Graphics Card Replacement: passo 5, imagem 1 %32 Raidmax Alpha Case Graphics Card Replacement: passo 5, imagem 2 %32 Raidmax Alpha Case Graphics Card Replacement: passo 5, imagem 3 %32
    • Carefully slide the glass panel to the left and then pull it off to remove it.
    Pergunte ao FixBot
    Comentar
  6. Raidmax Alpha Case Graphics Card Replacement: passo 6, imagem 1 %32 Raidmax Alpha Case Graphics Card Replacement: passo 6, imagem 2 %32 Raidmax Alpha Case Graphics Card Replacement: passo 6, imagem 3 %32
    • Tilt the case backward and lay it on its backside. This is done so the card will not pull down when being removed.
    Pergunte ao FixBot
    Comentar
  7. Raidmax Alpha Case Graphics Card Replacement: passo 7, imagem 1 %32 Raidmax Alpha Case Graphics Card Replacement: passo 7, imagem 2 %32 Raidmax Alpha Case Graphics Card Replacement: passo 7, imagem 3 %32
    • Undo the power connection to the card. Push the clip on the connector and pull the cable up.
    Pergunte ao FixBot
    Comentar
  8. Raidmax Alpha Case Graphics Card Replacement: passo 8, imagem 1 %32 Raidmax Alpha Case Graphics Card Replacement: passo 8, imagem 2 %32 Raidmax Alpha Case Graphics Card Replacement: passo 8, imagem 3 %32
    • Remove three 6.3 mm screws to the card located on the left side of the case using a Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  9. Raidmax Alpha Case Graphics Card Replacement: passo 9, imagem 1 %32 Raidmax Alpha Case Graphics Card Replacement: passo 9, imagem 2 %32
    • Push down the clip to the motherboard circled in red.
    Pergunte ao FixBot
    Comentar
  10. Raidmax Alpha Case Graphics Card Replacement: passo 10, imagem 1 %32 Raidmax Alpha Case Graphics Card Replacement: passo 10, imagem 2 %32 Raidmax Alpha Case Graphics Card Replacement: passo 10, imagem 3 %32
    • Carefully grip the old graphics card with two hands and lift it out of the case.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 80
Ao todo: 4,830
