Ir para o conteúdo principal
Radiator/thermostat valve repair
O que você precisa
  1. Radiator/thermostat valve repair, Radiator-/thermostat-valve: passo 1, imagem 1 %32
    • Fully open the thermostat/valve
  2. Radiator/thermostat valve repair: passo 2, imagem 1 %32
    • Undo the screw on the fastening clamp. In this case an older thermostat is shown. Newer models probably have a twist and screw cap and you may not need tools at all.
    • Remove the thermostat head.
  3. Radiator/thermostat valve repair: passo 3, imagem 1 %32
    • Put some multipurpose oil onto the little transmission pin.
  4. Radiator/thermostat valve repair: passo 4, imagem 1 %32
    • By tapping the pin CAREFULLY with a hammer, you can make it move again.
  5. Radiator/thermostat valve repair: passo 5, imagem 1 %32 Radiator/thermostat valve repair: passo 5, imagem 2 %32
    • Add some additional lubrication to the pin before screwing the thermostat back on.
    • By pushing the pin in and let it come back out several times using the hammer again, the oil should evenly distribute on the pin, so that in future it is very unlikely, that it is seizing up soon again.
    • That's it! Put the valve/thermostat back on and fix it in place.
Conclusão
To reassemble your device, follow the steps in reverse order.
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Martin Herterich
Membro desde: 01/08/20
211 Reputação
Autoria de 1 guia
Equipe
iFixit EU Team Membro de iFixit EU Team
Community
52 Membros
5.314 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 64
Duração total: 383
