Ir para o conteúdo principal
Radeon RX 580 Video Card Fan Replacement
O que você precisa
  1. Radeon RX 580 Video Card Fan Replacement, Remove the outer panels: passo 1, imagem 1 %32 Radeon RX 580 Video Card Fan Replacement, Remove the outer panels: passo 1, imagem 2 %32 Radeon RX 580 Video Card Fan Replacement, Remove the outer panels: passo 1, imagem 3 %32
    • Lay down the case so that the power button is on the far top right corner and is facing your right.
    • Remove the top panel by pushing its ridgeline away from you and sliding it off of the case.
    • Remove the side panel facing you by pushing its ridgeline away from you and lifting it off of the case.
  2. Radeon RX 580 Video Card Fan Replacement, Disconnect the GPU cable: passo 2, imagem 1 %32 Radeon RX 580 Video Card Fan Replacement, Disconnect the GPU cable: passo 2, imagem 2 %32
    • To disconnect the GPU cable, use your thumb and index finger to unlatch the hooking device and pull the cable away.
  3. Radeon RX 580 Video Card Fan Replacement, Release from the motherboard: passo 3, imagem 1 %32 Radeon RX 580 Video Card Fan Replacement, Release from the motherboard: passo 3, imagem 2 %32
    • Gently and carefully press down on the release mechanism on the PCIE slot of the graphics card.
    • You should hear a click which will indicate proper release from the motherboard (in this case a Tomahawk B450).
    • Do not touch the motherboard with your hands or any other device. It may result in a short.
  4. Radeon RX 580 Video Card Fan Replacement, Take the card out: passo 4, imagem 1 %32 Radeon RX 580 Video Card Fan Replacement, Take the card out: passo 4, imagem 2 %32 Radeon RX 580 Video Card Fan Replacement, Take the card out: passo 4, imagem 3 %32
    • Remove the graphics card from the motherboard by applying back pressure to the card.
    • Use both hands in this process as the card can be quite heavy.
    • Be sure to set the graphics card on a non-static surface, such as a wooden table.
  5. Radeon RX 580 Video Card Fan Replacement, Unscrew both fans: passo 5, imagem 1 %32 Radeon RX 580 Video Card Fan Replacement, Unscrew both fans: passo 5, imagem 2 %32
    • Remove the six 1.8 mm screws holding both fans in place by using a Phillips #1 screwdriver in-between the fan blades as the screws are located behind the fans.
    • Do not touch the heat sink with your screwdriver as it may cause substantial damage to the system.
  6. Radeon RX 580 Video Card Fan Replacement, Remove both fans: passo 6, imagem 1 %32 Radeon RX 580 Video Card Fan Replacement, Remove both fans: passo 6, imagem 2 %32
    • Remove the fans by applying back pressure.
    • Unplug the individual fans from the graphics card.
Conclusão
Uma outra pessoa concluiu este guia.
4 comentários
this will not work this way unless you cut and slice wires because the fan connection is under the heatsink. this card needs the be completely opened and thermal compound replaced to replace the fans properly without jerry rigging your fans
J M - Responder
This tutorial is not complete, some extra steps are required to unplug the fans power connector.
Indeed, it’s necessary to remove the plastic support above the heat sink (where fans are screwed on) to be able to unplug the fans power connector.
First, the fan support should be removed and the connector should be unplugged before unscrewing the fans from the plastic support.
Brendan - Responder
I have a Gigabyte rx580 ,, is this card easier to unplug than your example .. looks awkward to get to the plug
Graham Holliday - Responder
Görüntü ekrana gelmiyor...onboard olarak takıldığın da görüntü var...teknik servisten birisi bir proğram yüklemeniz gerekli demişti ...nasıl olucak nasıl yapacağız...görüntü yok çünkü
Mamiofficial - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 48
Últimos 30 dias: 183
Duração total: 6,572
