Ir para o conteúdo principal
RYDIS H68 Pro Side Brush Motor Replacement
O que você precisa
  1. RYDIS H68 Pro Side Brush Motor Replacement, Battery: passo 1, imagem 1 %32 RYDIS H68 Pro Side Brush Motor Replacement, Battery: passo 1, imagem 2 %32
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Side Brush Motor Replacement: passo 2, imagem 1 %32
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: passo 3, imagem 1 %32 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: passo 3, imagem 2 %32 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: passo 3, imagem 3 %32
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Side Brush Motor Replacement: passo 4, imagem 1 %32 RYDIS H68 Pro Side Brush Motor Replacement: passo 4, imagem 2 %32 RYDIS H68 Pro Side Brush Motor Replacement: passo 4, imagem 3 %32
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Side Brush Motor Replacement: passo 5, imagem 1 %32 RYDIS H68 Pro Side Brush Motor Replacement: passo 5, imagem 2 %32 RYDIS H68 Pro Side Brush Motor Replacement: passo 5, imagem 3 %32
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Side Brush Motor Replacement, Side Brush Motor: passo 6, imagem 1 %32
    • Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
    • Unlatch the latches indicated. It can be easily done with your finger.
    • Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
    • The reason for these first few steps is to avoid damaging the signal wires for the sensor.
  7. RYDIS H68 Pro Side Brush Motor Replacement: passo 7, imagem 1 %32
    • This step just shows you how everything looks after the previous steps were completed.
    • There are sensors on both the left and right side. This can be done for either side.
  8. RYDIS H68 Pro Side Brush Motor Replacement: passo 8, imagem 1 %32
    • Unscrew the five 10mm screws using a Phillips #1 screwdriver.
  9. RYDIS H68 Pro Side Brush Motor Replacement: passo 9, imagem 1 %32
    • The side brush motor can now be removed by lifting it up.
Conclusão
Uma outra pessoa concluiu este guia.
jude auguste
Membro desde: 02/15/17
108 Reputação
Autoria de 1 guia
Equipe
USFT-Lacy-S17S005G2 Membro de USFT-Lacy-S17S005G2
Local Repair Groups
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 617
