Introdução
The side brushes are a problem many people encounter when dealing with the RYDIS H68 Pro. This guide will show you how to fix a side brush issue.
O que você precisa
Flip the vacuum over so that the wheels are facing you.
Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
Unlatch the latches indicated. It can be easily done with your finger.
Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
Uma outra pessoa concluiu este guia.
