Ir para o conteúdo principal
RK5 PLUS VR Headset Headband Replacement
O que você precisa
  1. RK5 PLUS VR Headset Headband Replacement, Headband: passo 1, imagem 1 %32 RK5 PLUS VR Headset Headband Replacement, Headband: passo 1, imagem 2 %32 RK5 PLUS VR Headset Headband Replacement, Headband: passo 1, imagem 3 %32
    • Place the headset right side up and facing you on a flat surface.
    • Gently detach the velcro straps from the top, left, and right sides of the headset and set them aside.
  2. RK5 PLUS VR Headset Headband Replacement: passo 2, imagem 1 %32
    • Remove the white headband adjustment part and carefully pull it off of the three straps.
  3. RK5 PLUS VR Headset Headband Replacement: passo 3, imagem 1 %32 RK5 PLUS VR Headset Headband Replacement: passo 3, imagem 2 %32 RK5 PLUS VR Headset Headband Replacement: passo 3, imagem 3 %32
    • To access the straps that need to be replaced, remove the padding around the visual lenses of the headset.
    • To do this, use your hands to detach the plastic frame between the padding and the lenses.
    • If you need help getting started, use a spudger or opening tool and undo the clips holding the plastic frame.
    • Unhook the old straps from the sides of the headset.
  4. RK5 PLUS VR Headset Headband Replacement: passo 4, imagem 1 %32 RK5 PLUS VR Headset Headband Replacement: passo 4, imagem 2 %32 RK5 PLUS VR Headset Headband Replacement: passo 4, imagem 3 %32
    • Reattach the new velcro straps to each of the white hooks.
    • Make sure the straps are securely attached to the hooks before moving on to the next step.
  5. RK5 PLUS VR Headset Headband Replacement: passo 5, imagem 1 %32 RK5 PLUS VR Headset Headband Replacement: passo 5, imagem 2 %32
    • Reattach the plastic frame with the padded back onto the headset.
    • Make sure the padding is properly aligned and clicked into place.
  6. RK5 PLUS VR Headset Headband Replacement: passo 6, imagem 1 %32 RK5 PLUS VR Headset Headband Replacement: passo 6, imagem 2 %32 RK5 PLUS VR Headset Headband Replacement: passo 6, imagem 3 %32
    • Reattach the top band into the top hook of the headset.
    • Take the other sides of the velcro straps and hook them into the white headband adjustment part.
    • Check that the straps are properly aligned and securely attached to the headband adjustment part.
  7. RK5 PLUS VR Headset Headband Replacement: passo 7, imagem 1 %32
    • You have successfully replaced your damaged headbands for the RK5 Plus VR headset!
Conclusão
Faraaz Abdul
Membro desde: 01/30/23
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 281
