Ir para o conteúdo principal
RIDGID R860052 Direction of Rotation Selector Replacement
O que você precisa
  1. RIDGID R860052 Direction of Rotation Selector Replacement, Direction of Rotation Selector: passo 1, imagem 1 %32 RIDGID R860052 Direction of Rotation Selector Replacement, Direction of Rotation Selector: passo 1, imagem 2 %32
    • Remove the battery from the drill before you begin.
    • Use a T10 Torx screwdriver to remove the ten screws on the information label side of the drill.
    • These ten screws are 19 mm long.
  2. RIDGID R860052 Direction of Rotation Selector Replacement: passo 2, imagem 1 %32
    • Lift off and remove the cover with the informational label.
  3. RIDGID R860052 Direction of Rotation Selector Replacement: passo 3, imagem 1 %32 RIDGID R860052 Direction of Rotation Selector Replacement: passo 3, imagem 2 %32 RIDGID R860052 Direction of Rotation Selector Replacement: passo 3, imagem 3 %32
    • Lift up the switch assembly.
    • Unhook the rotation selector from the drill cover and replace with a new one.
Conclusão
Uma outra pessoa concluiu este guia.
Anna Wu
Membro desde: 02/04/19
273 Reputação
Autoria de 2 guias
Equipe
UC Davis, Team S18-G4, Lore Winter 2019 Membro de UC Davis, Team S18-G4, Lore Winter 2019
UCD-LORE-W19S18G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 253
