Ir para o conteúdo principal
RIDGID R84015 X2 Planetary Gear Replacement Guide
O que você precisa
  1. RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: passo 1, imagem 1 %32 RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: passo 1, imagem 2 %32
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Planetary Gear Replacement Guide: passo 2, imagem 1 %32
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Planetary Gear Replacement Guide: passo 3, imagem 1 %32 RIDGID R84015 X2 Planetary Gear Replacement Guide: passo 3, imagem 2 %32
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Planetary Gear Replacement Guide, Planetary Gear: passo 4, imagem 1 %32
    • Prepare to remove the gear chamber.
    • Using the Phillips #2 screwdriver, unscrew the four screws at the rear of the plastic gear chamber.
  5. RIDGID R84015 X2 Planetary Gear Replacement Guide: passo 5, imagem 1 %32 RIDGID R84015 X2 Planetary Gear Replacement Guide: passo 5, imagem 2 %32
    • Remove the motor from the drill by gently pulling the motor away from the gear chamber.
    • NOTE: Handle the gear chamber with caution as the gears are now loose.
  6. RIDGID R84015 X2 Planetary Gear Replacement Guide: passo 6, imagem 1 %32
    • Remove the plastic gear chamber.
    • Using the Phillips #2 screwdriver, remove the four screws that attach the plastic gear chamber.
  7. RIDGID R84015 X2 Planetary Gear Replacement Guide: passo 7, imagem 1 %32 RIDGID R84015 X2 Planetary Gear Replacement Guide: passo 7, imagem 2 %32
    • Remove each component from the gear assembly. Replace components as needed.
    • Reassemble the drill following the gear replacement instructions in reverse order.
Linha de Chegada
4 outras pessoas executaram este guia.
Evan Long
Membro desde: 04/15/10
262 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 15-48, Garner Spring 2010 Membro de Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
Membros da 6
Autoria de 10 guias
Um comentário
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 6,217
