Ir para o conteúdo principal
RIDGID R84015 X2 Disassembly
O que você precisa
  1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: passo 1, imagem 1 %32 RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: passo 1, imagem 2 %32
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Disassembly: passo 2, imagem 1 %32
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Disassembly: passo 3, imagem 1 %32 RIDGID R84015 X2 Disassembly: passo 3, imagem 2 %32
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: passo 4, imagem 1 %32
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  5. RIDGID R84015 X2 Disassembly: passo 5, imagem 1 %32
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  6. RIDGID R84015 X2 Disassembly: passo 6, imagem 1 %32
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  7. RIDGID R84015 X2 Disassembly: passo 7, imagem 1 %32
    • Make sure plastic is not broken and switch is not stuck.
Linha de Chegada
Brian
Membro desde: 04/12/10
97 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-48, Garner Spring 2010 Membro de Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
Membros da 6
Autoria de 10 guias
Um comentário
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 39
Duração total: 13,575
