Ir para o conteúdo principal
RIDGID R2740 Ball Bearing Replacement
O que você precisa
  1. RIDGID R2740 Ball Bearing Replacement, Ball Bearing: passo 1, imagem 1 %32 RIDGID R2740 Ball Bearing Replacement, Ball Bearing: passo 1, imagem 2 %32
    • Orient the belt sander so that the AirGuard Technology logo is facing you.
    • Remove the nine 19mm, two 51mm and one 32 mm screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
  2. RIDGID R2740 Ball Bearing Replacement: passo 2, imagem 1 %32
    • Remove the assembly armature from the belt sander.
    • You may need to wiggle the assembly armature to remove it from the belt sander.
  3. RIDGID R2740 Ball Bearing Replacement: passo 3, imagem 1 %32 RIDGID R2740 Ball Bearing Replacement: passo 3, imagem 2 %32
    • Use a hammer to pry the ball bearing from the assembly armature.
    • The ball bearing can be somewhat difficult to remove. You may need to apply WD-40 before removal.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 20
Duração total: 1,013
