Ir para o conteúdo principal
RIDGID Belt Sander R2740 Tension Lever Spring Replacement
O que você precisa
  1. RIDGID Belt Sander R2740 Tension Lever Spring Replacement, Tension Lever Spring: passo 1, imagem 1 %32
    • Turn the belt sander so that the RIDGID logo is facing you.
    • Flip the tension lever to the open position so that the tension on the spring is released.
    • Remove any sandpaper that is on the belt sander.
  2. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: passo 2, imagem 1 %32 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: passo 2, imagem 2 %32 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: passo 2, imagem 3 %32
    • Using the T20 Torx Screwdriver, remove the two (2) M4 X 19 mm screws on either side of the the belt tension release lever.
    • Remove the side plate to reveal the spring.
  3. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: passo 3, imagem 1 %32 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: passo 3, imagem 2 %32
    • Remove and replace the spring (OD 14.47mm X 38.1mm).
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 27
Duração total: 1,700
