Ir para o conteúdo principal
RIDGID Belt Sander R2740 Power Cord Replacement
O que você precisa
  1. RIDGID Belt Sander R2740 Power Cord Replacement, Power Cord: passo 1, imagem 1 %32 RIDGID Belt Sander R2740 Power Cord Replacement, Power Cord: passo 1, imagem 2 %32
    • Orient the belt sander so that the RIDGID logo is facing you.
    • Remove the six 19 mm and three 51 mm T20 screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
  2. RIDGID Belt Sander R2740 Power Cord Replacement: passo 2, imagem 1 %32 RIDGID Belt Sander R2740 Power Cord Replacement: passo 2, imagem 2 %32
    • Remove the two 16 mm T10 screws.
    • Remove the support bracket that holds the power cord into place.
  3. RIDGID Belt Sander R2740 Power Cord Replacement: passo 3, imagem 1 %32 RIDGID Belt Sander R2740 Power Cord Replacement: passo 3, imagem 2 %32 RIDGID Belt Sander R2740 Power Cord Replacement: passo 3, imagem 3 %32
    • Lift the power cord from the resting grooves.
    • Rotate the switch so that the lock-on button is facing you.
    • Loosen the two 8 mm Phillips #3 screws.
    • Pull the two wires away from the switch.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 643
