Ir para o conteúdo principal
RIDGID Belt Sander R2740 On/Off Switch Replacement
O que você precisa
  1. RIDGID Belt Sander R2740 On/Off Switch Replacement, Power Cord: passo 1, imagem 1 %32 RIDGID Belt Sander R2740 On/Off Switch Replacement, Power Cord: passo 1, imagem 2 %32
    • Orient the belt sander so that the RIDGID logo is facing you.
    • Remove the six 19 mm and three 51 mm T20 screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
  2. RIDGID Belt Sander R2740 On/Off Switch Replacement: passo 2, imagem 1 %32 RIDGID Belt Sander R2740 On/Off Switch Replacement: passo 2, imagem 2 %32
    • Remove the two 16 mm T10 screws.
    • Remove the support bracket that holds the power cord into place.
  3. RIDGID Belt Sander R2740 On/Off Switch Replacement: passo 3, imagem 1 %32 RIDGID Belt Sander R2740 On/Off Switch Replacement: passo 3, imagem 2 %32 RIDGID Belt Sander R2740 On/Off Switch Replacement: passo 3, imagem 3 %32
    • Lift the power cord from the resting grooves.
    • Rotate the switch so that the lock-on button is facing you.
    • Loosen the two 8 mm Phillips #3 screws.
    • Pull the two wires away from the switch.
  4. RIDGID Belt Sander R2740 On/Off Switch Replacement, On/Off Switch: passo 4, imagem 1 %32
    • Undo the two screws on the backside of the switch with a Phillips #3 screw driver.
  5. RIDGID Belt Sander R2740 On/Off Switch Replacement: passo 5, imagem 1 %32
    • Pull out the wires from the switch.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 811
