Introdução
If your RIDGID Belt Sander is low on power or does not turn on at all, you may need to replace the motor brushes. This guide will show you how to replace the motor brushes on your belt sander. For this task you will just need a standard screw driver.
O que você precisa
Move to the front side of the sander.
Remove the brush cap with a standard screw driver.
Quase terminado!
Conclusão
