Ir para o conteúdo principal
RCX 1.0 Case Replacement
O que você precisa
  1. RCX 1.0 Case Replacement, Batteries: passo 1, imagem 1 %32
    • Place the RCX on a flat surface.
  2. RCX 1.0 Case Replacement: passo 2, imagem 1 %32
    • Flip the RCX over so its black IR window is facing away from you.
  3. RCX 1.0 Case Replacement: passo 3, imagem 1 %32
    • Remove the gray battery cover by lifting from the front (near the IR window). Raise it at an angle and remove it to reveal the green battery compartment.
    • You can now remove the batteries and insert new ones.
  4. RCX 1.0 Case Replacement, Case: passo 4, imagem 1 %32
    • Remove the four screws in the battery compartment. These hold the yellow top on.
  5. RCX 1.0 Case Replacement: passo 5, imagem 1 %32 RCX 1.0 Case Replacement: passo 5, imagem 2 %32
    • Turn the RCX so the IR window points up.
    • Pull the right side of the battery compartment away from the top case. The left side will be held in place by the battery clip.
    • Lift the bottom of the black IR window. Pull it out.
  6. RCX 1.0 Case Replacement: passo 6, imagem 1 %32 RCX 1.0 Case Replacement: passo 6, imagem 2 %32
    • Hold the exposed edge of the circuit board with your fingers and pull the top case off, starting at the front. This takes considerable force.
    • Make sure the case doesn't get stuck on the power connector on the back of the RCX.
  7. RCX 1.0 Case Replacement: passo 7, imagem 1 %32
    • Hold the battery compartment and twist the circuit board counterclockwise.
    • There is a little nub of plastic at each end of the battery compartment that you must lift the board over as you turn it.
  8. RCX 1.0 Case Replacement: passo 8, imagem 1 %32 RCX 1.0 Case Replacement: passo 8, imagem 2 %32
    • Remove the buttons from the top case. (They probably fell out already.)
    • Squeeze the clips at the top and bottom of each Lego 9V connector. Push them through.
Conclusão
To reassemble your device, follow these instructions in reverse order. If you bent the battery clips when you removed the circuit board, bend them back down so they make contact with the solder on the board. The orientation of the gray battery cover doesn't matter.
9 outras pessoas executaram este guia.
notexactly
Membro desde: 05/18/10
375 Reputação
Autoria de 2 guias
4 comentários
As you can see, I was rushing when I did this guide. I'm planning to redo the disassembly next weekend and take landscape-oriented photos with better lighting and a white background.
notexactly - Responder
Guia simple y directa, justo lo que buscaba, Buen trabajo
Alejandro Castillo - Responder
It’s a GREAT guide, thank you! I bought an RCX off Ebay and found batteries inside that expired 6 years ago. You can imagine the corroded mess I’m cleaning up. Thanks to your guide I have it apart and cleaning.
Brian Wall - Responder
Guten tag, ich habe mir einen lego Mindstorms RCX 1.0 im Internet gekauft und dieser war ungetestet und jonnte möglicherweise einen Wasserschaden haben, leider hat er auch einen Wasserschaden, was kann ich da tun, ich habe alles auseinander gebaut und alles kontrolliert, alle kondensatoren sind ganz, sowie alle Bauelemente auf der Platine. Bitte antworten sie mir unter der E-Mail johannaman60@gmail.com danke!
TECHNIK FREAKS MJ - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 6,247
