Ir para o conteúdo principal
RCX 1.0 Batteries Replacement
  1. RCX 1.0 Batteries Replacement, Batteries: passo 1, imagem 1 %32
    • Place the RCX on a flat surface.
  2. RCX 1.0 Batteries Replacement: passo 2, imagem 1 %32
    • Flip the RCX over so its black IR window is facing away from you.
  3. RCX 1.0 Batteries Replacement: passo 3, imagem 1 %32
    • Remove the gray battery cover by lifting from the front (near the IR window). Raise it at an angle and remove it to reveal the green battery compartment.
    • You can now remove the batteries and insert new ones.
Conclusão
To reassemble your device, follow these instructions in reverse order. The orientation of the gray battery cover doesn't matter.
3 outras pessoas executaram este guia.
notexactly
Membro desde: 05/18/10
375 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 2,603
