Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
In order to replace the viewfinder on your RCA Small Wonders Camcorder CC176, it only takes a small flathead screwdriver, a safe place to keep the screws that you will take out of the camcorder, and a little bit of patience.
O que você precisa
Remove the 5 screws that secure the control panel (located on the top of the device) by using your small flathead screwdriver.
Loosen the panel from the device until you are able to remove it.
