Ir para o conteúdo principal
RCA Small Wonders Camcorder CC176 Viewfinder Replacement
O que você precisa
  1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: passo 1, imagem 1 %32 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: passo 1, imagem 2 %32 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: passo 1, imagem 3 %32
    • Remove the 5 screws that secure the control panel (located on the top of the device) by using your small flathead screwdriver.
    • Loosen the panel from the device until you are able to remove it.
  2. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: passo 2, imagem 1 %32 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: passo 2, imagem 2 %32 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: passo 2, imagem 3 %32
    • Remove the remaining 21 screws on the camcorder.
    • Begin separating the plastic casing from the inner components of the device.
  3. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: passo 3, imagem 1 %32 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: passo 3, imagem 2 %32
    • Grasping the viewfinder in hand, carefully remove the two screws that secure the mounting device.
    • Locate the gray electrical cord that connects the viewfinder to the inner components of the camera. Gently unplug the gray cord and loosen the viewfinder from the device.
    • Separate the viewfinder from the device and feed the gray cord through the hole in the plastic casing.
Conclusão
Allison Baudoin
Membro desde: 12/05/11
401 Reputação
Autoria de 4 guias
Equipe
James Madison, Team 2-1, Allen Fall 2011 Membro de James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
Membros da 2
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 1,287
