Ir para o conteúdo principal
RCA Small Wonders Camcorder CC176 Top Control Panel Replacement
O que você precisa
  1. RCA Small Wonders Camcorder CC176 Top Control Panel Replacement, Top Control Panel: passo 1, imagem 1 %32 RCA Small Wonders Camcorder CC176 Top Control Panel Replacement, Top Control Panel: passo 1, imagem 2 %32
    • Remove the 5 small black screws along the edges of the control panel at the top of the device.
    • Wedge a small flathead screwdriver around the edges of the panel. Loosen the edges of the panel until it pops away from the device.
    • Locate the blue circuit strip along the underside of the control panel and disconnect it from the inner components of the device.
    • Remove the top control panel from the device after it has been disconnected.
Conclusão
Allison Baudoin
Membro desde: 12/05/11
401 Reputação
Autoria de 4 guias
Equipe
James Madison, Team 2-1, Allen Fall 2011 Membro de James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
Membros da 2
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 900
