Ir para o conteúdo principal
RCA Small Wonders Camcorder CC176 Speaker Replacement
O que você precisa
  1. RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: passo 1, imagem 1 %32 RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: passo 1, imagem 2 %32 RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Remove the small black screws along the edges of the control panel on the top of the device.
    • Pry off the top control panel using the plastic wedge tool.
    • Remove the screw from the front, gray panel located beneath the "Scene Select AE" label.
    • Remove the two small black screws on the top of the front, gray panel of the device, above the red AUTOFOCUS letters.
  2. RCA Small Wonders Camcorder CC176 Speaker Replacement: passo 2, imagem 1 %32
    • Turn the device over and remove the two screws securing the front panel of the device.
    • Remove the screw securing the primary viewfinder, along the front of the camera.
    • Using a flat plastic tool, pry the entire front panel away from the device.
  3. RCA Small Wonders Camcorder CC176 Speaker Replacement: passo 3, imagem 1 %32 RCA Small Wonders Camcorder CC176 Speaker Replacement: passo 3, imagem 2 %32
    • Gently unplug the grey cord, located underneath the panel, disconnecting the speaker from the inner component of the device.
    • Remove the speaker from the device.
Conclusão
Allison Baudoin
Membro desde: 12/05/11
401 Reputação
Autoria de 4 guias
Equipe
James Madison, Team 2-1, Allen Fall 2011 Membro de James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
Membros da 2
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 938
