Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Ferramentas
Nenhuma ferramenta especificada.
Peças
  1. Lay down your remote as shown
    • Lay down your remote as shown
  2. Pull back on the plastic tab with your fingernail
    • Pull back on the plastic tab with your fingernail
  3. After pulling up, the panel will be unlatched Lift it
    • After pulling up, the panel will be unlatched
    • Lift it
  4. The panel is now free from the remote Remove it
    • The panel is now free from the remote
    • Remove it
  5. Depress on each battery, on the side which does NOT have a spring Once depressed, lift up and remove each battery.
    • Depress on each battery, on the side which does NOT have a spring
    • Once depressed, lift up and remove each battery.
Conclusão
Levi G
Membro desde: 13/07/2018
2.678 Reputação
20 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 31
