Ir para o conteúdo principal
RCA RP3715A Speaker Replacement
O que você precisa
  1. RCA RP3715A Speaker Replacement, Reaching the battery terminal.: passo 1, imagem 1 %32 RCA RP3715A Speaker Replacement, Reaching the battery terminal.: passo 1, imagem 2 %32
    • Push down on the clip to release pressure. The pull off the plastic cover.
  2. RCA RP3715A Speaker Replacement, Replacing the battery: passo 2, imagem 1 %32
    • Remove the 9-volt battery from the battery terminal.
  3. RCA RP3715A Speaker Replacement, Getting inside the device.: passo 3, imagem 1 %32
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  4. RCA RP3715A Speaker Replacement, Relieve extension cord tension.: passo 4, imagem 1 %32 RCA RP3715A Speaker Replacement, Relieve extension cord tension.: passo 4, imagem 2 %32 RCA RP3715A Speaker Replacement, Relieve extension cord tension.: passo 4, imagem 3 %32
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  5. RCA RP3715A Speaker Replacement: passo 5, imagem 1 %32 RCA RP3715A Speaker Replacement: passo 5, imagem 2 %32
    • Using flathead screwdriver undo the release tabs.
  6. RCA RP3715A Speaker Replacement: passo 6, imagem 1 %32 RCA RP3715A Speaker Replacement: passo 6, imagem 2 %32 RCA RP3715A Speaker Replacement: passo 6, imagem 3 %32
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  7. RCA RP3715A Speaker Replacement: passo 7, imagem 1 %32 RCA RP3715A Speaker Replacement: passo 7, imagem 2 %32
    • Pry open both tabs to remove the topside of the clock.
  8. RCA RP3715A Speaker Replacement, Speaker Replacement: passo 8, imagem 1 %32
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
Conclusão
Uma outra pessoa concluiu este guia.
Myles Waiters
Membro desde: 09/22/14
370 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 10-5, Brown Fall 2014 Membro de USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 209
