Ir para o conteúdo principal
RCA RP3715A Motherboard Replacement
O que você precisa
  1. RCA RP3715A Motherboard Replacement, Getting inside the device.: passo 1, imagem 1 %32
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  2. RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: passo 2, imagem 1 %32 RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: passo 2, imagem 2 %32 RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: passo 2, imagem 3 %32
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  3. RCA RP3715A Motherboard Replacement: passo 3, imagem 1 %32 RCA RP3715A Motherboard Replacement: passo 3, imagem 2 %32
    • Using flathead screwdriver undo the release tabs.
  4. RCA RP3715A Motherboard Replacement: passo 4, imagem 1 %32 RCA RP3715A Motherboard Replacement: passo 4, imagem 2 %32 RCA RP3715A Motherboard Replacement: passo 4, imagem 3 %32
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  5. RCA RP3715A Motherboard Replacement: passo 5, imagem 1 %32 RCA RP3715A Motherboard Replacement: passo 5, imagem 2 %32
    • Pry open both tabs to remove the topside of the clock.
  6. RCA RP3715A Motherboard Replacement, Speaker Replacement: passo 6, imagem 1 %32
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
  7. RCA RP3715A Motherboard Replacement, Detaching the front panel: passo 7, imagem 1 %32
    • Remove the two 10 mm Phillip's #1 screws.
  8. RCA RP3715A Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the gray panel from the frame.
  9. RCA RP3715A Motherboard Replacement, Unlatch release tabs: passo 9, imagem 1 %32 RCA RP3715A Motherboard Replacement, Unlatch release tabs: passo 9, imagem 2 %32 RCA RP3715A Motherboard Replacement, Unlatch release tabs: passo 9, imagem 3 %32
    • The two latches located in the picture will help take off the display.
    • Remove the display.
  10. RCA RP3715A Motherboard Replacement, Motherboard: passo 10, imagem 1 %32 RCA RP3715A Motherboard Replacement, Motherboard: passo 10, imagem 2 %32
    • asd
  11. RCA RP3715A Motherboard Replacement, Removing the top part of motherboard: passo 11, imagem 1 %32
    • Remove the top 5 10mm Phillips #1 screws holding the top part of the motherboard
  12. RCA RP3715A Motherboard Replacement, Removing the side part of motherboard: passo 12, imagem 1 %32
    • Remove the 5 10mm Phillip's #1 screws that holding side part of the motherboard
  13. RCA RP3715A Motherboard Replacement: passo 13, imagem 1 %32
    • Remove the transformer by pulling back the release tab shown.
  14. RCA RP3715A Motherboard Replacement: passo 14, imagem 1 %32
    • Pull the battery terminal through the whole shown.
  15. RCA RP3715A Motherboard Replacement, Lift the digital screen: passo 15, imagem 1 %32
    • First release the latch highlighted in the picture. Then grab the screen by the bottom and lift it up.
  16. RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: passo 16, imagem 1 %32 RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: passo 16, imagem 2 %32 RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: passo 16, imagem 3 %32
    • Remove the motherboard from the frame using the illustration shown.
Conclusão
Uma outra pessoa concluiu este guia.
Alexander Trowell
Membro desde: 09/22/14
222 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 10-5, Brown Fall 2014 Membro de USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 546
