Ir para o conteúdo principal
RCA RCT6773W22 Battery Replacement
O que você precisa
  1. RCA RCT6773W22 Battery Replacement, Battery: passo 1, imagem 1 %32 RCA RCT6773W22 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Battery Replacement: passo 2, imagem 1 %32 RCA RCT6773W22 Battery Replacement: passo 2, imagem 2 %32 RCA RCT6773W22 Battery Replacement: passo 2, imagem 3 %32
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Battery Replacement: passo 3, imagem 1 %32 RCA RCT6773W22 Battery Replacement: passo 3, imagem 2 %32 RCA RCT6773W22 Battery Replacement: passo 3, imagem 3 %32
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
Conclusão
Kelsea Weber
Membro desde: 11/12/15
19.858 Reputação
Autoria de 32 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.764 guias
Um comentário
Umm, which battery do you need for it? Seems that’s a part that is kind of important.
Cathy Hajo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 3,829
