Ir para o conteúdo principal
RCA RCT6303W87 Speaker Replacement
O que você precisa
  1. RCA RCT6303W87 Speaker Replacement, Battery: passo 1, imagem 1 %32 RCA RCT6303W87 Speaker Replacement, Battery: passo 1, imagem 2 %32 RCA RCT6303W87 Speaker Replacement, Battery: passo 1, imagem 3 %32
    • Remove nine 4.8mm screws around the case with a JIS #00 screwdriver.
  2. RCA RCT6303W87 Speaker Replacement: passo 2, imagem 1 %32
    • Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
  3. RCA RCT6303W87 Speaker Replacement: passo 3, imagem 1 %32 RCA RCT6303W87 Speaker Replacement: passo 3, imagem 2 %32 RCA RCT6303W87 Speaker Replacement: passo 3, imagem 3 %32
    • Remove cover completely.
  4. RCA RCT6303W87 Speaker Replacement: passo 4, imagem 1 %32 RCA RCT6303W87 Speaker Replacement: passo 4, imagem 2 %32 RCA RCT6303W87 Speaker Replacement: passo 4, imagem 3 %32
    • Disconnect battery cable from the motherboard.
  5. RCA RCT6303W87 Speaker Replacement: passo 5, imagem 1 %32 RCA RCT6303W87 Speaker Replacement: passo 5, imagem 2 %32 RCA RCT6303W87 Speaker Replacement: passo 5, imagem 3 %32
    • Pull the thin black keyboard connector off and set it aside.
  6. RCA RCT6303W87 Speaker Replacement: passo 6, imagem 1 %32 RCA RCT6303W87 Speaker Replacement: passo 6, imagem 2 %32 RCA RCT6303W87 Speaker Replacement: passo 6, imagem 3 %32
    • Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
  7. RCA RCT6303W87 Speaker Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Use nylon spudger tool or plastic card to separate battery from the case.
  8. RCA RCT6303W87 Speaker Replacement: passo 8, imagem 1 %32 RCA RCT6303W87 Speaker Replacement: passo 8, imagem 2 %32 RCA RCT6303W87 Speaker Replacement: passo 8, imagem 3 %32
    • Carefully peel off the battery.
  9. RCA RCT6303W87 Speaker Replacement, Speaker: passo 9, imagem 1 %32 RCA RCT6303W87 Speaker Replacement, Speaker: passo 9, imagem 2 %32 RCA RCT6303W87 Speaker Replacement, Speaker: passo 9, imagem 3 %32
    • Disconnect the speaker cord from the motherboard.
  10. RCA RCT6303W87 Speaker Replacement: passo 10, imagem 1 %32 RCA RCT6303W87 Speaker Replacement: passo 10, imagem 2 %32 RCA RCT6303W87 Speaker Replacement: passo 10, imagem 3 %32
    • Use the plastic spudger to slide the speaker out.
Conclusão
Equipe
IUPUI, Team S3-G2, Harley Spring 2018 Membro de IUPUI, Team S3-G2, Harley Spring 2018
IUPUI-HARLEY-S18S3G2
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 445
