Ir para o conteúdo principal
RCA Pro10 Edition Speaker Replacement
O que você precisa
  1. RCA Pro10 Edition Speaker Replacement, Speaker: passo 1, imagem 1 %32 RCA Pro10 Edition Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Speaker Replacement: passo 2, imagem 1 %32
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Speaker Replacement: passo 3, imagem 1 %32 RCA Pro10 Edition Speaker Replacement: passo 3, imagem 2 %32
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
Conclusão
Dayne Russell
Membro desde: 01/27/15
401 Reputação
Autoria de 4 guias
Equipe
Pasco Hernando, Team 1-1, Prince Winter 2015 Membro de Pasco Hernando, Team 1-1, Prince Winter 2015
PHSC-PRINCE-W15S1G1
Membros da 6
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 769
