O que você precisa
Using a separating tool, look for a seam in the plastic casing that looks most accessible.
Use the prying tool to separate the front and back casing, working your way around the perimeter.
Utilize a card tool or a pick to assist in keeping the case separated.
Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
Peel back the beige tape while holding down the camera ribbon cable to prevent tears
Use a P00 Phillips screwdriver to remove the three screws securing the button board.
Desolder the contacts on the button board to remove or replace it.
Uma outra pessoa concluiu este guia.
