Ir para o conteúdo principal
RCA Pro10 Edition Display Screen Replacement
O que você precisa
  1. RCA Pro10 Edition Display Screen Replacement, Speaker: passo 1, imagem 1 %32 RCA Pro10 Edition Display Screen Replacement, Speaker: passo 1, imagem 2 %32
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Display Screen Replacement: passo 2, imagem 1 %32
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Display Screen Replacement: passo 3, imagem 1 %32 RCA Pro10 Edition Display Screen Replacement: passo 3, imagem 2 %32
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. RCA Pro10 Edition Display Screen Replacement, Camera: passo 4, imagem 1 %32 RCA Pro10 Edition Display Screen Replacement, Camera: passo 4, imagem 2 %32 RCA Pro10 Edition Display Screen Replacement, Camera: passo 4, imagem 3 %32
    • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
    • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
  5. RCA Pro10 Edition Display Screen Replacement: passo 5, imagem 1 %32 RCA Pro10 Edition Display Screen Replacement: passo 5, imagem 2 %32
    • Lift the locking tab that is securing the camera ribbon cable.
    • Slide the ribbon cable out from the connector and remove from casing.
  6. RCA Pro10 Edition Display Screen Replacement, Power/Volume Buttons: passo 6, imagem 1 %32
    • Use a P00 Phillips screwdriver to remove the three screws securing the button board.
    • Desolder the contacts on the button board to remove or replace it.
  7. RCA Pro10 Edition Display Screen Replacement, Battery: passo 7, imagem 1 %32 RCA Pro10 Edition Display Screen Replacement, Battery: passo 7, imagem 2 %32
    • Peel off the black tape on the battery and main-board.
    • Peel off the black tape securing the screen ribbon cable to the back of the screen.
    • Use caution to avoid damaging either ribbon cable.
  8. RCA Pro10 Edition Display Screen Replacement: passo 8, imagem 1 %32 RCA Pro10 Edition Display Screen Replacement: passo 8, imagem 2 %32
    • Slide out the ribbon cable lock that is securing the screen ribbon cable.
    • Move the ribbon cable out of the way using tape if necessary.
  9. RCA Pro10 Edition Display Screen Replacement: passo 9, imagem 1 %32 RCA Pro10 Edition Display Screen Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Remove the yellow tape securing the battery to the screen.
    • Use a plastic card or pick to separate the battery from the screen.
    • Do not bend or puncture battery, battery is difficult to separate from screen.
    • Cut or desolder the wires on the battery to remove or replace it.
  10. RCA Pro10 Edition Display Screen Replacement, Display Screen: passo 10, imagem 1 %32
    • Peel the WiFi antenna off of the monitor and move out of the way.
  11. RCA Pro10 Edition Display Screen Replacement: passo 11, imagem 1 %32 RCA Pro10 Edition Display Screen Replacement: passo 11, imagem 2 %32 RCA Pro10 Edition Display Screen Replacement: passo 11, imagem 3 %32
    • Remove the black tape on the screen and the main-board.
    • Lift the ribbon cable lock securing the digitizer ribbon cable.
    • Slide out the digitizer ribbon cable and move away from the device, use tape to secure if necessary.
  12. RCA Pro10 Edition Display Screen Replacement: passo 12, imagem 1 %32
    • Use a P00 Phillips screwdriver to remove the three screws securing the main-board to the back casing.
  13. RCA Pro10 Edition Display Screen Replacement: passo 13, imagem 1 %32 RCA Pro10 Edition Display Screen Replacement: passo 13, imagem 2 %32 RCA Pro10 Edition Display Screen Replacement: passo 13, imagem 3 %32
    Comprar
    • Lift the main-board up and away from the ports to reveal the microphone.
    • Use tweezers to remove the microphone from the black silicone.
    • Move the main-board off the screen.
  14. RCA Pro10 Edition Display Screen Replacement: passo 14, imagem 1 %32 RCA Pro10 Edition Display Screen Replacement: passo 14, imagem 2 %32
    • Use a separator tool to lift the screen from the port side of the casing and remove it.
    • To reassemble the device, follow these steps in reverse unless specified otherwise.
Conclusão
9 outras pessoas executaram este guia.
Tyler Schuster
Membro desde: 01/27/15
476 Reputação
Autoria de 1 guia
Equipe
Pasco Hernando, Team 1-1, Prince Winter 2015 Membro de Pasco Hernando, Team 1-1, Prince Winter 2015
PHSC-PRINCE-W15S1G1
Membros da 6
Autoria de 10 guias
4 comentários
Gracias y ademas la buenas fotografias ayudaron una inmesidad.
Kl
Klaus laage - Responder
Nothing spectacular happened I just turned on my tablet today and voila! My display is crazed on part of the screen! I read these steps a couple times and I just don't understand how if this process is intended to replace the display screen a display screen isn't listed as a necessary part purchase. I have faith in reader generated sites so please help!
Denise Engle - Responder
Denise a new display screen would need to be purchased. Unless you absolutely have to have this particular tablet fixed I suggest buying a new one.
Chris Blackwell -
hola, podrás tener este repuesto de la pantalla lcd para la venta para ese modelo?
gracias
William Weygel
williamw666@hotmail.com
William Weygel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 6,267
