Ir para o conteúdo principal
RCA Maven Pro 11 Motherboard Replacement
O que você precisa
  1. RCA Maven Pro 11 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 RCA Maven Pro 11 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 RCA Maven Pro 11 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Use a Phillip's head screwdriver to unscrew the screws that secure the back cover in place. There are 6 screws in total (4 black, 2 silver).
  2. RCA Maven Pro 11 Motherboard Replacement: passo 2, imagem 1 %32 RCA Maven Pro 11 Motherboard Replacement: passo 2, imagem 2 %32 RCA Maven Pro 11 Motherboard Replacement: passo 2, imagem 3 %32
    • Using a prying tool to pry off the back cover of the tablet. To do this, insert the prying tool between the screen and the side of the tablet.
    • Once the prying tool is inserted, run it along the edge of the tablet until the back cover pops off.
  3. RCA Maven Pro 11 Motherboard Replacement: passo 3, imagem 1 %32
    • Use a Phillips head screwdriver to unscrew the 4 black screws that secure the motherboard to the device.
  4. RCA Maven Pro 11 Motherboard Replacement: passo 4, imagem 1 %32 RCA Maven Pro 11 Motherboard Replacement: passo 4, imagem 2 %32 RCA Maven Pro 11 Motherboard Replacement: passo 4, imagem 3 %32
    • On the long edge of the motherboard, remove all of the ribbon and bundled cables.
    • The ZIF connections are removed by lifting up the small black tab on the connector and simply pulling out the ribbon cable(s).
    • Insert a spudger or plastic opening tool under the lip of the white bundled cable connector(s), and push the connector(s) free.
  5. RCA Maven Pro 11 Motherboard Replacement: passo 5, imagem 1 %32 RCA Maven Pro 11 Motherboard Replacement: passo 5, imagem 2 %32 RCA Maven Pro 11 Motherboard Replacement: passo 5, imagem 3 %32
    • On the short edge of the motherboard, remove the yellow wire. To do this, lift up the clamp and pull out the wire.
  6. RCA Maven Pro 11 Motherboard Replacement: passo 6, imagem 1 %32
    • Lift motherboard off the back of the tablet.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 537
