Ir para o conteúdo principal
RCA Lyra X2400 USB port replacement
O que você precisa
  1. RCA Lyra X2400 USB port replacement, Screen: passo 1, imagem 1 %32 RCA Lyra X2400 USB port replacement, Screen: passo 1, imagem 2 %32
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  2. RCA Lyra X2400 USB port replacement: passo 2, imagem 1 %32 RCA Lyra X2400 USB port replacement: passo 2, imagem 2 %32
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  3. RCA Lyra X2400 USB port replacement: passo 3, imagem 1 %32 RCA Lyra X2400 USB port replacement: passo 3, imagem 2 %32 RCA Lyra X2400 USB port replacement: passo 3, imagem 3 %32
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  4. RCA Lyra X2400 USB port replacement, Motherboard: passo 4, imagem 1 %32 RCA Lyra X2400 USB port replacement, Motherboard: passo 4, imagem 2 %32
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  5. RCA Lyra X2400 USB port replacement, USB in/out: passo 5, imagem 1 %32 RCA Lyra X2400 USB port replacement, USB in/out: passo 5, imagem 2 %32
    • Locate the USB in/out component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
    • Start using solder/desolder tools to remove the USB in/out.
    • Once removed replace it with the new working USB in/out.
    • Use the soldering tools to reattach the component back to the main logic board.
Conclusão
Joseph Goodwin
Membro desde: 04/11/13
1 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-3, Regan Spring 2013 Membro de Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Ao todo: 287
