Ir para o conteúdo principal
RCA Lyra X2400 Motherboard Replacement
O que você precisa
  1. RCA Lyra X2400 Motherboard Replacement, Battery: passo 1, imagem 1 %32 RCA Lyra X2400 Motherboard Replacement, Battery: passo 1, imagem 2 %32 RCA Lyra X2400 Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
    • Remove the battery plate.
    • Place your finger at the bottom of the battery.
    • Lift up on the battery until it pops out from the LYRA X2400.
  2. RCA Lyra X2400 Motherboard Replacement, Screen: passo 2, imagem 1 %32 RCA Lyra X2400 Motherboard Replacement, Screen: passo 2, imagem 2 %32
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  3. RCA Lyra X2400 Motherboard Replacement: passo 3, imagem 1 %32 RCA Lyra X2400 Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  4. RCA Lyra X2400 Motherboard Replacement: passo 4, imagem 1 %32 RCA Lyra X2400 Motherboard Replacement: passo 4, imagem 2 %32 RCA Lyra X2400 Motherboard Replacement: passo 4, imagem 3 %32
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. RCA Lyra X2400 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 RCA Lyra X2400 Motherboard Replacement, Motherboard: passo 5, imagem 2 %32
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
Conclusão
Evan Lindquist
Membro desde: 04/11/13
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-3, Regan Spring 2013 Membro de Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 346
