Ir para o conteúdo principal
RCA CC310 Viewfinder Replacement
O que você precisa
  1. RCA CC310 Viewfinder Replacement, Viewfinder: passo 1, imagem 1 %32 RCA CC310 Viewfinder Replacement, Viewfinder: passo 1, imagem 2 %32
    • Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
    • Pushing the viewfinder assembly to the right makes lifting the flap easier.
    • Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
  2. RCA CC310 Viewfinder Replacement: passo 2, imagem 1 %32 RCA CC310 Viewfinder Replacement: passo 2, imagem 2 %32 RCA CC310 Viewfinder Replacement: passo 2, imagem 3 %32
    • Unscrew the 7mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable connects off of the viewfinder assembly.
    • Disconnect the cable inside by pulling it apart.
  3. RCA CC310 Viewfinder Replacement: passo 3, imagem 1 %32 RCA CC310 Viewfinder Replacement: passo 3, imagem 2 %32
    • Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up and remove.
  4. RCA CC310 Viewfinder Replacement: passo 4, imagem 1 %32
    • Flip back the viewfinder access tab.
    • Unscrew the 7.0mm ph #0 screw next to the mirror.
  5. RCA CC310 Viewfinder Replacement: passo 5, imagem 1 %32 RCA CC310 Viewfinder Replacement: passo 5, imagem 2 %32 RCA CC310 Viewfinder Replacement: passo 5, imagem 3 %32
    • Lift off both sides of the plastic assembly.
    • When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
  6. RCA CC310 Viewfinder Replacement: passo 6, imagem 1 %32 RCA CC310 Viewfinder Replacement: passo 6, imagem 2 %32
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  7. RCA CC310 Viewfinder Replacement: passo 7, imagem 1 %32 RCA CC310 Viewfinder Replacement: passo 7, imagem 2 %32 RCA CC310 Viewfinder Replacement: passo 7, imagem 3 %32
    • Lift plastic housing and guide the wires from underneath.
    • Lift out the entire circuit board and viewfinder.
    • Replace entire circuit board and viewfinder assembly.
Conclusão
Oliver Adams
Membro desde: 01/19/11
629 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 5-20, Amido Winter 2011 Membro de Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membros
Autoria de 7 guias
1Comentário do guia
do you know where i can find a relacement one of these parts
Connor Byrley - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 2,679
