Ir para o conteúdo principal
RCA CC310 Onboard Speaker Replacement
O que você precisa
    1. RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: passo 1, imagem 1 %32 RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: passo 1, imagem 2 %32
      • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
      • Remove the one 3.8mm Phillips #0 screw on the bottom.
      • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
      Pergunte ao FixBot
      Comentar
    2. RCA CC310 Onboard Speaker Replacement: passo 2, imagem 1 %32 RCA CC310 Onboard Speaker Replacement: passo 2, imagem 2 %32
      • Remove 5.8mm Phillips #1 screw from the side button panel.
      • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
      Pergunte ao FixBot
      Comentar
    3. RCA CC310 Onboard Speaker Replacement: passo 3, imagem 1 %32 RCA CC310 Onboard Speaker Replacement: passo 3, imagem 2 %32
      • Pry along the seam on the top side near the buttons with a spudger.
      Pergunte ao FixBot
      Comentar
    4. RCA CC310 Onboard Speaker Replacement: passo 4, imagem 1 %32 RCA CC310 Onboard Speaker Replacement: passo 4, imagem 2 %32
      • Pull the left panel away from the rest of the camcorder.
      • Unplug the red speaker cable located at the rear of the device.
      • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
      Pergunte ao FixBot
      Comentar
    1. RCA CC310 Onboard Speaker Replacement, Onboard Speaker: passo 5, imagem 1 %32 RCA CC310 Onboard Speaker Replacement, Onboard Speaker: passo 5, imagem 2 %32
      • Unplug the red cable connecting the speaker to the motherboard.
      Pergunte ao FixBot
      Comentar
    2. RCA CC310 Onboard Speaker Replacement: passo 6, imagem 1 %32 RCA CC310 Onboard Speaker Replacement: passo 6, imagem 2 %32
      • Locate the speaker on the removed panel. Find the groove on the top left side of the speaker.
      • Pry the plastic up with a spudger until the glue breaks and the speaker is detached.
      Pergunte ao FixBot
      Comentar
    3. RCA CC310 Onboard Speaker Replacement: passo 7, imagem 1 %32
      • Break the plastic pieces holding the cable to the panel.
      • Glue the new cables, with a hot glue gun, back to the panel after replacing the speaker.
      Pergunte ao FixBot
      Comentar
    4. RCA CC310 Onboard Speaker Replacement: passo 8, imagem 1 %32 RCA CC310 Onboard Speaker Replacement: passo 8, imagem 2 %32 RCA CC310 Onboard Speaker Replacement: passo 8, imagem 3 %32
      • Glue the new speaker to the panel.
      • Plug the cable back into the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Oliver Adams
Membro desde: 01/19/11
629 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 5-20, Amido Winter 2011 Membro de Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membros
Autoria de 49 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 1,389
