Ir para o conteúdo principal
RCA CC310 Onboard Speaker Replacement
O que você precisa
  1. RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: passo 1, imagem 1 %32 RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: passo 1, imagem 2 %32
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Onboard Speaker Replacement: passo 2, imagem 1 %32 RCA CC310 Onboard Speaker Replacement: passo 2, imagem 2 %32
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Onboard Speaker Replacement: passo 3, imagem 1 %32 RCA CC310 Onboard Speaker Replacement: passo 3, imagem 2 %32
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Onboard Speaker Replacement: passo 4, imagem 1 %32 RCA CC310 Onboard Speaker Replacement: passo 4, imagem 2 %32
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Onboard Speaker Replacement, Onboard Speaker: passo 5, imagem 1 %32 RCA CC310 Onboard Speaker Replacement, Onboard Speaker: passo 5, imagem 2 %32
    • Unplug the red cable connecting the speaker to the motherboard.
  6. RCA CC310 Onboard Speaker Replacement: passo 6, imagem 1 %32 RCA CC310 Onboard Speaker Replacement: passo 6, imagem 2 %32
    • Locate the speaker on the removed panel. Find the groove on the top left side of the speaker.
    • Pry the plastic up with a spudger until the glue breaks and the speaker is detached.
  7. RCA CC310 Onboard Speaker Replacement: passo 7, imagem 1 %32
    • Break the plastic pieces holding the cable to the panel.
    • Glue the new cables, with a hot glue gun, back to the panel after replacing the speaker.
  8. RCA CC310 Onboard Speaker Replacement: passo 8, imagem 1 %32 RCA CC310 Onboard Speaker Replacement: passo 8, imagem 2 %32 RCA CC310 Onboard Speaker Replacement: passo 8, imagem 3 %32
    • Glue the new speaker to the panel.
    • Plug the cable back into the motherboard.
Conclusão
Oliver Adams
Membro desde: 01/19/11
629 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 5-20, Amido Winter 2011 Membro de Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 1,102
