Ir para o conteúdo principal
RCA 8 Apollo Camera Replacement
O que você precisa
  1. RCA 8 Apollo Camera Replacement, Back Panel: passo 1, imagem 1 %32
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
  2. RCA 8 Apollo Camera Replacement: passo 2, imagem 1 %32 RCA 8 Apollo Camera Replacement: passo 2, imagem 2 %32
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
  3. RCA 8 Apollo Camera Replacement: passo 3, imagem 1 %32 RCA 8 Apollo Camera Replacement: passo 3, imagem 2 %32
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
  4. RCA 8 Apollo Camera Replacement, Display Assembly: passo 4, imagem 1 %32 RCA 8 Apollo Camera Replacement, Display Assembly: passo 4, imagem 2 %32 RCA 8 Apollo Camera Replacement, Display Assembly: passo 4, imagem 3 %32
    • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
    • Remove the yellow tape that is around the battery.
    • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
    • If the connector is misaligned, the pins can bend, causing permanent damage.
  5. RCA 8 Apollo Camera Replacement: passo 5, imagem 1 %32
    • Remove the three screws from the motherboard using a Phillips screwdriver.
  6. RCA 8 Apollo Camera Replacement: passo 6, imagem 1 %32
    • Remove the battery and motherboard together from the tablet.
    • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
    • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
  7. RCA 8 Apollo Camera Replacement, Camera: passo 7, imagem 1 %32 RCA 8 Apollo Camera Replacement, Camera: passo 7, imagem 2 %32
    • Remove the front facing and back facing cameras from the top of the tablet.
Conclusão
Chantel Pfiefer
Membro desde: 04/15/24
219 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 83
