Ir para o conteúdo principal
RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement
O que você precisa
  1. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: passo 1, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: passo 1, imagem 2 %32 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: passo 1, imagem 3 %32
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 2, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 3, imagem 1 %32
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 4, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 4, imagem 2 %32
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Battery: passo 5, imagem 1 %32
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 6, imagem 1 %32
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 7, imagem 1 %32
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 8, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 9, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 9, imagem 2 %32
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
  10. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Antenna: passo 10, imagem 1 %32
    • Identify the grey wire on the right side of the device.
  11. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the orange ribbon cable over the wire.
  12. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 12, imagem 1 %32
    • Remove the antenna using a soldering iron.
  13. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Motherboard: passo 13, imagem 1 %32
    • Remove the blue and black wire from the top of the motherboard.
  14. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 14, imagem 1 %32
    • Remove the screws from the motherboard.
  15. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: passo 15, imagem 1 %32
    • Remove the motherboard.
Conclusão
Marcus Elysee
Membro desde: 10/25/19
97 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 Membro de UMass Dartmouth, Team S1-G8, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G8
Membros da 3
Autoria de 4 guias
Um comentário
Where can I buy this motherboard?
waymond everett - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 23
Duração total: 1,354
