Ir para o conteúdo principal
RCA 10 Viking Pro RCT6K03W13 Battery Replacement
O que você precisa
  1. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: passo 1, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: passo 1, imagem 2 %32 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: passo 1, imagem 3 %32
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 2, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 2, imagem 2 %32
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 3, imagem 1 %32
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 4, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 4, imagem 2 %32
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 6, imagem 1 %32
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 7, imagem 1 %32
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 8, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 8, imagem 2 %32
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 9, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: passo 9, imagem 2 %32
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
Conclusão
5 outras pessoas executaram este guia.
Ryan Wickett
Membro desde: 10/25/19
632 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 Membro de UMass Dartmouth, Team S1-G8, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G8
Membros da 3
Autoria de 4 guias
4 comentários
Where can I get the battery for this?
Justin - Responder
You can get a battery from Amazon or Walmart.com your wellcome ?
GLENDA Vandergrift -
How much voltage should the battery put out in order for the tablet to turn on?
Jesus Rios - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 33
Duração total: 3,062
