Ir para o conteúdo principal
RCA 10 Viking Pro RCT6K03W13 Antenna Replacement
O que você precisa
  1. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: passo 1, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: passo 1, imagem 2 %32 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Backplate: passo 1, imagem 3 %32
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 2, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 2, imagem 2 %32
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 3, imagem 1 %32
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 4, imagem 1 %32 RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 4, imagem 2 %32
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement, Antenna: passo 5, imagem 1 %32
    • Identify the grey wire on the right side of the device.
  6. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 6, imagem 1 %32
    • Remove the orange ribbon cable over the wire.
  7. RCA 10 Viking Pro RCT6K03W13 Antenna Replacement: passo 7, imagem 1 %32
    • Remove the antenna using a soldering iron.
Conclusão
Ryan Wickett
Membro desde: 10/25/19
632 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 Membro de UMass Dartmouth, Team S1-G8, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G8
Membros da 3
Autoria de 4 guias
Um comentário
Does anyone know where I can buy a new antenna for this device?
DIY_Human - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 393
