Ir para o conteúdo principal
Quiksilver The Fifty50 Analog Battery Replacement
O que você precisa
  1. Quiksilver The Fifty50 Analog Battery Replacement, Strap: passo 1, imagem 1 %32 Quiksilver The Fifty50 Analog Battery Replacement, Strap: passo 1, imagem 2 %32
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Analog Battery Replacement: passo 2, imagem 1 %32 Quiksilver The Fifty50 Analog Battery Replacement: passo 2, imagem 2 %32
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Analog Battery Replacement, Back Panel: passo 3, imagem 1 %32 Quiksilver The Fifty50 Analog Battery Replacement, Back Panel: passo 3, imagem 2 %32
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Analog Battery Replacement: passo 4, imagem 1 %32
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
  5. Quiksilver The Fifty50 Analog Battery Replacement, Analog Battery: passo 5, imagem 1 %32 Quiksilver The Fifty50 Analog Battery Replacement, Analog Battery: passo 5, imagem 2 %32
    • Carefully lift the white plastic circular out of the watch.
  6. Quiksilver The Fifty50 Analog Battery Replacement: passo 6, imagem 1 %32 Quiksilver The Fifty50 Analog Battery Replacement: passo 6, imagem 2 %32 Quiksilver The Fifty50 Analog Battery Replacement: passo 6, imagem 3 %32
    • Remove the four 1.1 mm screws located on the metallic holder using the Phillips #00 screwdriver.
  7. Quiksilver The Fifty50 Analog Battery Replacement: passo 7, imagem 1 %32 Quiksilver The Fifty50 Analog Battery Replacement: passo 7, imagem 2 %32 Quiksilver The Fifty50 Analog Battery Replacement: passo 7, imagem 3 %32
    • Remove the large circular Analog battery.
Conclusão
Sue Giske
Membro desde: 07/16/19
634 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team S1-G4, Liner Summer 2019 Membro de UW Tacoma, Team S1-G4, Liner Summer 2019
UWT-LINER-SU19S1G4
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 756
