Ir para o conteúdo principal
Quantum XTR05 Pinion Gear Replacement
  1. Quantum XTR05 Pinion Gear Replacement, Pinion Gear: passo 1, imagem 1 %32 Quantum XTR05 Pinion Gear Replacement, Pinion Gear: passo 1, imagem 2 %32 Quantum XTR05 Pinion Gear Replacement, Pinion Gear: passo 1, imagem 3 %32
    • Unscrew by turning the cap counter-clockwise until it is separated from the spinning reel.
  2. Quantum XTR05 Pinion Gear Replacement: passo 2, imagem 1 %32 Quantum XTR05 Pinion Gear Replacement: passo 2, imagem 2 %32 Quantum XTR05 Pinion Gear Replacement: passo 2, imagem 3 %32
    • Remove the spool line completely by pulling it away from the reel body.
  3. Quantum XTR05 Pinion Gear Replacement: passo 3, imagem 1 %32 Quantum XTR05 Pinion Gear Replacement: passo 3, imagem 2 %32 Quantum XTR05 Pinion Gear Replacement: passo 3, imagem 3 %32
    • Remove the gear by pulling it up and off of the pinion.
    • Replace the pinion gear with your new one by aligning the shape of the gear opening and the pinion.
  4. Quantum XTR05 Pinion Gear Replacement: passo 4, imagem 1 %32 Quantum XTR05 Pinion Gear Replacement: passo 4, imagem 2 %32
    • Place the spool back onto the pinion.
    • Ensure that the spool is fitted properly.
  5. Quantum XTR05 Pinion Gear Replacement: passo 5, imagem 1 %32
    • Place the spool release and drag adjustment piece back onto the top of the pinion.
  6. Quantum XTR05 Pinion Gear Replacement: passo 6, imagem 1 %32
    • Screw the spool release and drag adjustment back into place in a clockwise direction until desired tension is achieved.
Linha de Chegada
Nicholas Lynch
Membro desde: 02/22/22
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 196
