Ir para o conteúdo principal
Quantum View 10.1 Battery Replacement
O que você precisa
  1. Quantum View 10.1 Battery Replacement, Open Quantum View case: passo 1, imagem 1 %32
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: passo 2, imagem 1 %32 Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: passo 2, imagem 2 %32
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 Battery Replacement, Unhooking the battery: passo 3, imagem 1 %32 Quantum View 10.1 Battery Replacement, Unhooking the battery: passo 3, imagem 2 %32
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
Conclusão
3 comentários
How do I find a replacement battery?
Chris Clayton - Responder
Seems finding the right battery is a problem
where can I find a replacement battery and screen for this i only have the motherboard lying around and i really want to repair it so i can access old data
aabel joby - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 887
