Ir para o conteúdo principal
Quantum Axis A23 Battery Replacement
O que você precisa
  1. Quantum Axis A23 Battery Replacement, Removing the Case: passo 1, imagem 1 %32
    • Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
    • Be careful not to crack front screen in the process.
  2. Quantum Axis A23 Battery Replacement, Removing the Tape: passo 2, imagem 1 %32
    • Once the device is open, remove the tape from the the battery.
  3. Quantum Axis A23 Battery Replacement, Prying the Battery Off the Screen: passo 3, imagem 1 %32
    • Carefully pry up the battery by wedging the plastic opening tool under the battery. It is glued to the screen so it will be a delicate removal process.
  4. Quantum Axis A23 Battery Replacement, Removing the Battery: passo 4, imagem 1 %32
    • Remove all tape connected to the battery.
  5. Quantum Axis A23 Battery Replacement: passo 5, imagem 1 %32
    • Once the battery is removed, take wire cutters to the two wires attaching the battery to the motherboard and cut the red and black wires in the middle. Then, strip the both the red and black wires halfway with the wire stripper/cutter tool.
    • It's important to cut the wires in the middle to ensure an easy replacement. Also, be careful when stripping the wires because they are delicate and likely to break apart.
    • When cutting the wires, CUT THEM ONE AT A TIME to avoid shorting the battery.
  6. Quantum Axis A23 Battery Replacement: passo 6, imagem 1 %32
    • Take the new battery and strip both the red and black wires in the middle with wire stripper/cutter tool.
    • Take the red wire from the battery and the red wire from your device's motherboard and twist the two ends together then wrap in electrical tape. Repeat this step for the black wires.
Conclusão
Tape the battery back onto the back of the device's screen and snap the rear case back on to finish this repair.
Nicole
Membro desde: 01/12/15
407 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-5, Tanski Winter 2015 Membro de USF Tampa, Team 1-5, Tanski Winter 2015
USFT-TANSKI-W15S1G5
3 Membros
Autoria de 10 guias
1Comentário do guia
Were can i purchase the battery?
Nisha Niles - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 564
