Ir para o conteúdo principal
Qualcomm Snapdragon 800 Mobile Development Antenna Replacement
O que você precisa
  1. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Battery: passo 1, imagem 1 %32 Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Battery: passo 1, imagem 2 %32
    • Locate your device.
    • Flip device onto its back.
  2. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: passo 2, imagem 1 %32
    • Remove the tablet's back cover.
  3. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: passo 3, imagem 1 %32
    • Locate the battery and remove it.
    • If you wish to replace the battery you can do so here.
  4. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Back Panel: passo 4, imagem 1 %32 Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Back Panel: passo 4, imagem 2 %32
    • Use the Phillips PH1 screwdriver to unscrew the five 4x2.5mm screws that hold the back cover.
  5. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: passo 5, imagem 1 %32
    • Pop out the back cover.
  6. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement, Antennas: passo 6, imagem 1 %32
    • After removing the panel and the battery, your tablet should look like this.
  7. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: passo 7, imagem 1 %32 Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: passo 7, imagem 2 %32
    • Locate the tablet's antennas.
    • Remove the two 3x2.5mm screws holding them down.
  8. Qualcomm Snapdragon 800 Mobile Development Antenna Replacement: passo 8, imagem 1 %32
    • Remove antennas and replace them as needed.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 231
