Ir para o conteúdo principal
Qualcomm QCP-2760 Motherboard Replacement
O que você precisa
  1. Qualcomm QCP-2760 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Qualcomm QCP-2760 Motherboard Replacement, Rear Backing: passo 2, imagem 1 %32 Qualcomm QCP-2760 Motherboard Replacement, Rear Backing: passo 2, imagem 2 %32
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
  3. Qualcomm QCP-2760 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Locate the four metal clips holding the motherboard onto the phone.
    • Pull the clips away from the motherboard while lifting the motherboard out of the case.
    • The motherboard is attached to the case by a fragile cable, do not apply any stress to the cable.
  4. Qualcomm QCP-2760 Motherboard Replacement: passo 4, imagem 1 %32 Qualcomm QCP-2760 Motherboard Replacement: passo 4, imagem 2 %32
    • Place the motherboard down so that the screen is facing up.
    • Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
    • Locate, but do not disconnect, the four screen clips.
  5. Qualcomm QCP-2760 Motherboard Replacement: passo 5, imagem 1 %32 Qualcomm QCP-2760 Motherboard Replacement: passo 5, imagem 2 %32
    • Flip the motherboard over so that the screen is facing down.
    • Again, be careful not to put stress on the speaker cable.
Conclusão
Graham
Membro desde: 09/30/14
107 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-4, Buehl Fall 2014 Membro de Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 274
