Introdução
Prior to this step, remove battery, phone backing, and motherboard
O que você precisa
Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
Find the seam between the front and back of the phone
Pry the seam open using a plastic opening tool, or your fingers.
Locate the four metal clips holding the motherboard onto the phone.
Pull the clips away from the motherboard while lifting the motherboard out of the case.
