Ferramentas
Peças
  1. Start with removing the three screws to open the case. After removing the screws pull/push the case to the backside to remove it.
    • Start with removing the three screws to open the case. After removing the screws pull/push the case to the backside to remove it.
  2. Now you can remove the power supply unit. This requires 5 more screws on the back and two inside the case to be removed. Now you can remove the power supply unit. This requires 5 more screws on the back and two inside the case to be removed.
    • Now you can remove the power supply unit. This requires 5 more screws on the back and two inside the case to be removed.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Remove the remaining two screws on the back side. Two more can be found on the bottom and one on the bottom corner left and right. Noch you can careful remove the back of the UX-500P. Remove the remaining two screws on the back side. Two more can be found on the bottom and one on the bottom corner left and right. Noch you can careful remove the back of the UX-500P. Remove the remaining two screws on the back side. Two more can be found on the bottom and one on the bottom corner left and right. Noch you can careful remove the back of the UX-500P.
    • Remove the remaining two screws on the back side. Two more can be found on the bottom and one on the bottom corner left and right. Noch you can careful remove the back of the UX-500P.
  5. Now you can remove the final four screws that attaches the 120mm fan to the back of the UX500-P. Now you can remove the final four screws that attaches the 120mm fan to the back of the UX500-P.
    • Now you can remove the final four screws that attaches the 120mm fan to the back of the UX500-P.
Conclusão
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Chris Klinger
33 reputação
Autoria de 1 guia
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Todo: 62
